Re: Tire Ballast
Posted by David G on November 18, 2012 at 09:54:33 from (205.215.206.18):
In Reply to: Re: Tire Ballast posted by Dude with a 300 on November 18, 2012 at 07:53:27:
The extra weight is probably most important for loader work. It does take a lot of steel to make up for the 800 pounds per tire that ballast provides.
I would recommend changing the tubes every ten years if you want to run ballast. There seems to be a point between 10-20 that they start to leak.
