Posted by Centex Farmall on November 18, 2012 at 09:54:53 from (166.183.227.196):
In Reply to: just curious. posted by Tuckermac on November 18, 2012 at 07:37:23:
Forgot to include this in my rambling post:
At the tractor shows around here you see mostly fixed up and restored Deere tractors. However, while on your drive to and from the show you will spot same vintage IH tractors still in the field doing work.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
