Posted by John T on November 18, 2012 at 10:17:07 from (216.249.82.117):
In Reply to: Re: not enough spark posted by FBH44 on November 18, 2012 at 09:30:00:
True, small gap changes dont make any night n day difference, but it can make some especially if things are already at the margin of operation.
When the coil conducts current theres x amount of finite energy stored. When the plug fires all that energy less heat losses gets dissipated across the arcing plug gap in the form of Volts X Amps X Time. If you widen the gap the voltage must rise, so EITHER the current or arc duration (or both) has to be less. You still discharge x energy but the voltage rises if the gap is increased while current is what usually decreases.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
