Re: not enough spark
Posted by John T on November 18, 2012 at 10:18:44 from (216.249.82.117):
In Reply to: not enough spark posted by uncle henry on November 18, 2012 at 08:48:48:
Changing the gap a few thousands isnt gonna make her run much different. If the spark is weak the usual suspects are points, condensor, plug wires, cap n rotor problems
John T
