Posted by hattrick on November 18, 2012 at 15:09:39 from (216.57.221.66):
In Reply to: not enough spark posted by uncle henry on November 18, 2012 at 08:48:48:
Another thing that I have seen on cars is the coild can be installed backwards causing weak spark. Positive ground means negative to the coil positive from coil to distibutor. Negative ground would have positive to coil and negative from coil to distibutor. Easy enough to check just to make sure.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
