Re: 1566 won't start, even with ether
Posted by Jasondr on November 18, 2012 at 16:31:31 from (71.220.2.150):
In Reply to: 1566 won't start, even with ether posted by dryden j on November 15, 2012 at 21:55:57:
Well we figured it out. With all the cranking the hydraulic clutch was pumped up to pressure so we were able to pull it. Started pulling it and in about 15' it fired up. Then it went wild.
Started running away, the thottle did nothing, was running way over the governer. Probably 4000 rpm or more. Luckily we had the tube from the turbo to the intake manifold and there happened to be a 4 x4 in the rock box so I could shut it down with that otherwise there would have been some major engine work.
