Re: Farmall A Oil Filter (short or tall)
Posted by gene bender on November 18, 2012 at 18:30:33 from (207.177.56.85):
In Reply to: Re: Farmall A Oil Filter (short or tall) posted by Stevie J. Mote on November 18, 2012 at 17:49:18:
I get mine from Car Quest and they are made by Wix they are down at the shop and i get several when they have treir specials in Feb only cost a couple bucks. I dont remember just when they went to the short ones but over the yrs i do see where someone has changed sizes probably changed engines and it came with the tall ones.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
