Re: Question for Keith-OR
Posted by farmallhal on November 19, 2012 at 08:35:20 from (76.4.176.113):
In Reply to: Question for Keith-OR posted by Larry O on November 18, 2012 at 19:06:21:
Larry, what the pictures will show is like Old noted in his reply with the addition of a couple of lengths of 3/4" all thread with hex nuts on each end between the two pieces so a hydraulic jack can be fitted between those two 1/2" steel pieces and the front of the crankshaft. Then use something between the front of the crankshaft (smaller then the hole in the pulley like a socket) and use the hydraulic jack to pull the pulley off the crankshaft. The piece that fits in behind the pulley requires the U cut slot as noted by Old so the applied force is against the pulley hub and not the pulley flanges as it will break if pulled on the flanges. To reinstall the pulley after replacing the front seal just heat it in an oven so it will expand slightly and it should slip back over the crank if done quickly. Keith's tool doesn't have any reinstallation features. Hope this helps, Hal.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
