Re: Question for Keith-OR
Posted by El Toro on November 19, 2012 at 09:07:53 from (108.3.143.30):
In Reply to: Question for Keith-OR posted by Larry O on November 18, 2012 at 19:06:21:
third party image
I have that puller of Keith's on the computer somewhere. Haven't located it. Here's BigDog's
damper puller for his Cub. You would need to measure the hub on your damper pulley and use a split separator behind the pulley. You can either use a hydraulic ram or botle jack if it will work in the horizontal position. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
