Re: Fan belt adjustment 1953 or 54 Farmall
Posted by The Red on November 19, 2012 at 13:12:50 from (69.246.205.0):
In Reply to: Re: Fan belt adjustment 1953 or 54 Farmall posted by vet119 on November 19, 2012 at 11:15:13:
The H water pump has a locking screw or bolt on the inside pulley. Loosen that then you screw the inside pulley tighter. That would be counterclockwise when looking at it from the front. You might want to get that loosened up with a penetrate before you stick the belt back on. It is a pain if it has been awhile.
