Re: Re: Re: Farmall M shuts it's self off !!!!!!!
Posted by twopop on October 23, 2000 at 19:12:45 from (208.224.41.121):
In Reply to: Re: Re: Farmall M shuts it's self off !!!!!!! posted by ltf in nc on October 23, 2000 at 16:56:07:
I agree with ltf,but if you get plenty of fuel,hook up a test light to the coil at the ign. side and start the M watch the light and see if it goes out when it dies,if not hook it up to the dist, side and restart,the light should flash each time the engine fires.if these are both good,pull the coil wire and hold it so the spark will jump from the coil to the high tension lead,start again and see if spark stops.these tests should lead to your problem if it is not fuel
Post A Followup
: Re: Re: Re: Re: Farmall M shuts it's self off !!!!!!!
