Re: My first post.. Looking for your thoughts on my
Posted by Janicholson on November 19, 2012 at 20:24:12 from (96.24.99.126):
In Reply to: My first post.. Looking for your thoughts on my posted by werksguy on November 19, 2012 at 20:04:22:
1.This thing is WAY down on power..
Even a distillate should pull the stuffins out of an 8N
So don't tune till you analyze. Check the static timing, .
The question is, it's a distillate tractor. If I wind up re-doing the entire head, Wouldn't I be better off staring with the casting from a gas tractor?
The head off of a 350 is good.
2. I'm planning on putting a 3ph on my H. The hydraulics on my 8n drive me crazy, so I'm wanting to put a pump on the engine from an SH or 300. The tractor has a belly pump on it now... What pieces do I need to get to make all this work? When putting on a 3pt, use the front cover off of aSH 300 or 350 ---yes---, A mag is not as good as a distributor that is going to provide a centrifugal advance.. Jim
