Re: My first post.. Looking for your thoughts on my
Posted by Dean Olson on November 19, 2012 at 20:36:13 from (98.196.66.64):
In Reply to: My first post.. Looking for your thoughts on my posted by werksguy on November 19, 2012 at 20:04:22:
Do a compression test and if the engine is worn out, speaking from personal experience,
scrap/part out that one and look for a tractor in better shape.
You should be able to find an H or SH restored with 3ph for far less than you can redo that
one.
1.YES the distillate engine has much lower compression due to the head having big chambers.
Replace the head with one from a gas engine. Distillate heads have little value. Manifold and
carb are different. Distillate manifold and carb in good condition have some value. Look for a
SH,300,350 manifold and carb, especially if your going to rebuild it to SH or 300 specs.
2.The live hydraulic pump replaces the drive assembly that connect the timing gear cover to
the mag. The mag will work but I much prefer the distributor ignition. The timing gear and
cover on the older tractors won't work well with the live pump. Older gears are weaker and will
break. Timing cover bolts holes may not line up for the pump.
