Re: starter 6 to 12 volt conversion
Posted by John T on November 20, 2012 at 04:48:19 from (216.249.82.117):
In Reply to: starter 6 to 12 volt conversion posted by ruel on November 19, 2012 at 18:39:29:
I converted several to 12 volts and always kept the old 6 volt starter and all worked okay. A 6 volt solenoid (electric/magnetic switch, if thats what you have versus a mechanical switch) can still work also but if it ever burns out due to too much current and heat simply replace it with a 12 volt.
NOTE 1 it is a bit tougher on starter drives (Bendix) but mine all did okay despite that. Myself and my friend Bob M suggest if you convert and keep the 6 volt starter use a standard or lighter duty 12 volt battery (or even lighter gauge cables) NOT a huge honkin 1000 or more CCA as thats even tougher on starter drives.
NOTE 2 I have heard instances when a tractor had a Magneto ignition that the 6/12 cranking speed was so fast the mags (they do change timing at X RPM ya know) were firing at the advance run timing (maybe 20 BTDC) versus the needed like 0 Degrees start/impulse timing and that causes obviious problems.
John T
