Re: Live hydraulics
Posted by CNKS on November 20, 2012 at 05:37:52 from (216.144.104.128):
In Reply to: Live hydraulics posted by Notjustair on November 19, 2012 at 20:14:14:
You can get the equivalent of SAE 20 hyd oil or even 10W30 if you look around some. I would just use 30 wt engine oil if it is not shared with other tractors. If the temp bothers you use the 20 wt SAE equivalent or 20 engine oil.
