Posted by ONT656D on November 20, 2012 at 10:10:36 from (67.71.94.237):
Last winter my new to me 656 was slipping the PTO on my IH 80 blower. A complete change of hyd oil and filter helped enough to finish the winter. My local independent shop dismantled the PTO and completely rebuilt the unit, using IH parts. The fiber discs were cooked and some steel ones were bad. All was replaced, and the hyd oil and filter chanced again after 27 hours. Putting a pressure guage on now, the pressure is 50 pounds at initial engagement, HOWEVER, ( I hate that word...)when fully engaged, the reading is 105 pounds. He air pressure checked the unit before installation looking for leaks and found none. In my former farming days, I did a lot on 656s thru 1086s and never had a pressure problem. I talked to two older ( in their 70s) good old IH mechanics and they could not recall a pressure pump problem, nor is the power steering or remotes an issue, and the rear and the pto were free from debris.Is there something we are missing, or am faced with a pump replacement. Is there a cheaper solution, can I just replace the pump gears, machine the tolerances... Every hour of experimentation is on the meter. Thank you for all suggestions.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
