Water pump removal
Posted by BigTone on November 20, 2012 at 14:11:22 from (70.192.2.235):
Hey guys, im going to remove the water pump tomarrow and install the studs and springs that I failed to do the first time. I drained about 5 gallons of antifreeze from the bottom of the radiator, is that enough fluid out to remove the pump without losing that last gallon on the floor or should I drain what little bit is still in the block? that antifreeze is expensive, thats the only reason i ask. thanks for the help, ~Anthony
