Re: Farmall 706 Drain Plug for Hy-Tran
Posted by FC Andy on November 20, 2012 at 15:30:50 from (74.126.84.52):
In Reply to: Farmall 706 Drain Plug for Hy-Tran posted by John V. on November 20, 2012 at 11:35:52:
I think the 706 is like my 806. If so, there are at least 3 plugs- all of them are on the centerline of the axle- one on each of the axle housings right next to the main housing and one on the center of the main housing. All 3 need to be pulled to get the old oil out, unless it has had the hole drilled in the axle housings to let oil drain back to the center. If you have a "swinging" drawbar, you may need to pull it out to get at the center housing plug. I've pulled mine out for that purpose, at least. All 3 castings fill as one. IIRC there is also a plug to drain the PTO unit.
It may take a couple filter changes to get all the Jello out. The Jello is just Hy-tran that has absorbed as much water as it can. I had to change the filter 2 or 3 times when I first got my 806 going- and that was after changing the hy-tran! -Andy
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
