Re: Can't get '54 Super H to charge battery!!
Posted by gene bender on November 20, 2012 at 20:09:29 from (207.177.56.85):
In Reply to: Can't get '54 Super H to charge battery!! posted by ih555 on November 20, 2012 at 19:33:30:
Simple test with engine running ground the field and if that makes it charge the reg is bad if it doesent charge the gen is bad. Check to make sure gen,reg and lite control all have a good ground or the system just wont charge. Did you get the rite reg for your generator. Is it the original three brush that came with a cut-out or does your gen just have two brushes as that gen will take a different regulator no such thing as one reg fits all in this case.
