Re: Farmall A 3 point hitch??
Posted by PretendFarmer on November 21, 2012 at 04:34:05 from (192.249.47.207):
In Reply to: Farmall A 3 point hitch?? posted by Alek S. on November 21, 2012 at 01:57:22:
The easiest way in my opinion to make that work, is to get the implement lift for the plow. You can then use it to lift a 3 point hitch up and down.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
