Re: Case IH 234 diesel starting issue
Posted by Bob M on November 21, 2012 at 05:38:04 from (69.207.86.27):
In Reply to: Case IH 234 diesel starting issue posted by Michael Sheik on November 21, 2012 at 04:27:15:
My experience with that Mitsu diesel is the glowplugs must be in good shape in order for it to start quickly when cold.
When you crank do you see white exhaust out the stack? If yes, either your glowplugs are failing or the engine is suffering from low compression.
However if the exhaust is clear during cranking it's a fuel delivery issue. Could be a small leak letting air get into the suction side of the injection pump during a long shutdown.
