Re: Farmall A 3 point hitch??
Posted by El Toro on November 21, 2012 at 10:52:27 from (108.3.143.30):
In Reply to: Farmall A 3 point hitch?? posted by Alek S. on November 21, 2012 at 01:57:22:
If you have the old levers on your tractor for lifting and lowering implements I would use them. I had never installed the 16-inch moldboard plow on a Farmall A until 1976 when I got this A running. All the brackets were on the plow and I wasn't very long installing it. I'm not sure if I had to reverse the drawbar. The long lever will lift that plow easily. The other lever tilts the point. I was 43 then. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
