Re: Farmall A 3 point hitch??
Posted by athol carr on November 21, 2012 at 16:25:26 from (115.188.3.223):
In Reply to: Farmall A 3 point hitch?? posted by Alek S. on November 21, 2012 at 01:57:22:
The fenders on a Farmall Super A are lot heavier than the fenders on a Farmall A as they have to carry the rear rock-shaft for the lift system. The Farmall A rear lift rock-shaft was attached to the top of the transmission on the left-hand side and to a strap bolted to the seat support and fender on the right-hand side whereas in the Super A the rock-shaft is supported on the rear of the fender on each side.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
