Re: f400 starter intermittent drain
Posted by Janicholson on November 22, 2012 at 06:47:36 from (96.24.99.126):
In Reply to: f400 starter intermittent drain posted by jim_uny on November 22, 2012 at 06:40:18:
There is a better Starter drive. The issue is probably not the starter. If the battery is drained and things get hot, the starter relay (miscalled the solenoid) is sticking. If you know the relay is good, and the starter is not staying on, the battery may be bad, or not charging sufficiently. Starters of the type found on that tractor do not stay on by them selves. Jim
