Re: Gear oil for a Super C
Posted by gene bender on November 22, 2012 at 07:31:27 from (207.177.56.85):
In Reply to: Gear oil for a Super C posted by fred smith on November 22, 2012 at 05:19:23:
I wou7ld drain and then fill with 4 gal of diesel drive around a little then drain and refill with 150wt sure wont hurt. The straight cut gears can sure be noisy sometimes. I have found when replacing the input seal i also replace the bearing and most of the time it sure quiets the gear noise just makes sense if the input shaft has play the main shaft will transmit noise to other gears.
