Posted by Janicholson on November 22, 2012 at 17:08:28 from (96.24.99.126):
In Reply to: Blocking up H posted by David G on November 22, 2012 at 16:52:32:
Both the final housing, and the axle housing must be supported individually. The gasket can be eliminated, and black (or blue) RTV can be used. The bells will slide out enough to clean the surfaces if you are careful. Some use a new gasket and split it at the top, then use a dab of RTV to close the gap. Do not over use the sealant or it will squirt out into the system. Other than that, the bull gears would need to be removed from the axles to allow removal of the entire housing and axle. Doing it with the wheel and tire on is more challenge. Axle removal is able to be done through the PTO hole if you are small armed. Block up the bull gears to allow much easier insertion of the axles when going together. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
