Re: Re: ih cub stalls
Posted by Bob R on October 24, 2000 at 11:10:50 from (198.133.22.71):
In Reply to: Re: ih cub stalls posted by Bill {Antique Acres} on October 23, 2000 at 16:47:45:
Mine did that and it was a stuck valve . you can run the engine , and
pull one spark plug wire off . check for rpm drop . replace that plug wire . And continue . If you pull a plug and get no change . Thats your
bad cylinder .
Post what you find please .
Go off Bills post he's right on
Thought this will help too
Post A Followup
: Re: Re: Re: ih cub stalls
