any bolt that fails way below proper torque is prime for removal with a little bit of mechanical tapping. I would hold the rod securely in a good vice (with soft jaw protectors). I would use a prick punch or ice pic and place the point so as to turn the bolt out. It is also a prime candidate for a small square tapered easy out. (non spiral type.) I think it is not stuck, just broken from fatigue failure. I would not use any of them from that set. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
