Super C Hydraulics
Posted by Pete on October 24, 2000 at 13:32:34 from (205.227.43.11):
Need advice on my new machine which has been modified to include a 3 point hitch. There are two hydraulic hoses that run from the front of the tractor to the hydrualics in the rear. At the base of the tool kit in front of the seat is flat square device (pressure relief valve) where the lines hook into. The device spews hydraulic fluid when I try to lower the 3 point hitch. Thought, I might be able to replace an O ring but everything is rusted beyond recognition. Does anyone have any suggestions on how I might bypass or replace this unit?
Post A Followup
: Re: Super C Hydraulics
