Re: Broken bolt in connecting rod
Posted by rustyfarmall on November 23, 2012 at 06:50:20 from (216.248.71.226):
In Reply to: Broken bolt in connecting rod posted by Jim Paterson on November 22, 2012 at 17:24:54:
Find a nut that will fit inside the hole, and set on top of the broken bolt. Using a wire welder, weld ONLY in the hole in the center of that nut. Be generous with the weld, but DO NOT get outside of that center hole. Let everything cool down, put a socket on the nut and back it out.
