You have boiled it down to lack of air in cylinders. If you had restricted fuel return it would not deliver excess fuel as the internals of pump equalize and the pumping plungers will not take on fuel. If you can verify no restrictions right up to the valves them selves with intake and exhaust manifolds off you can forget about that. Next thing would be valve lift and valve timing. You need to verify that the valve timing is correct following procedure in manual, I don't have it on that model. I did see one John Deere tractor that had absolutely no power, smoke was normal for a fully loaded engine and the problem was transmission was over filled about 10 galons, filling the wet clutch flywheel compartment and placed a heavy load on engine when speeded up. But, if you have heavy black smoke with a normal injection pump setting you are just not getting air. If pump is over fueled you could get heavy black smoke from some external load problem in transmission or hydraulics. Not that familiar with that model though.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
