Posted by F12 guy on November 23, 2012 at 15:31:55 from (69.160.178.222):
Ok I finally got my f12 to crank and run. I have a couple questions. She will crank between the 3rd and 10th crank most times. After adjusting the valves and carb. after the motor has run 20 min like operators manual say she seams to run fine just seating at a ideal and full throttle. When I drive around she will act like she starving for gas just a little or missed fired on one cylinder. It's hard for me to tell. I can drive up a hill in 2nd gear and governor opens up and she will pull on up hill so this makes me think the timing is right or close. I have not changed timing since i put mag. On and timed it then. Could the carb. Load screw be to far in? I don't understand how she will pull up hill if screw is not out far enough. Could timing be off just a little? Any help welcomed thanks Josh in NC PS every thing in mag. Is new and carb.has been rebuilt.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
