Farmall Tractors Discussion Board
Re: Super A steering
Posted by Curt Cooke on January 14, 1999 at 05:39:35:
In Reply to: Super A steering posted by Grady on January 13, 1999 at 22:45:49:
Grady, there are no adjustments. Examine all points of steering from the steering wheel to the spindles. Eliminate the play one joint at a time. Some joints are more difficult than others but most of the play can be eliminated. Pay special attention to the point where the steering arm (that which transfers action to both tie rods in the center of the tractor)attaches to the verticle steering shaft. This is generally the most common source of the problem. Another common problem is the verticle steering shaft moving up and down when steering. This is usually caused by a bad bearing or a broken or missing snap ring. There's more but get this far first.
Post a Followup
: Re: Re: Super A steering
