Re: Char Lynn power assist steering
Posted by Notjustair on November 24, 2012 at 06:34:17 from (174.229.65.109):
In Reply to: Char Lynn power assist steering posted by Old Iron on November 23, 2012 at 19:39:20:
You have probably seen my posts on Char Lynn over the last couple of weeks. I've finally gotten mine up and running.
Does yours use it's own pump or a diverter from the hydraulics? There really isn't anything in the torque motor to go bad. I would suspect the supply. If it has it's own pump it could have a plugged filter and be starving for fluid. If it is off the main hydraulics your pump may be getting weak. Is it only at lower idle? Only after it is hot? Is it better in the cold weather?
