Re: Power Steering Compatibility
Posted by D Slater on November 24, 2012 at 13:11:12 from (184.15.8.142):
In Reply to: Power Steering Compatibility posted by Dude with a 300 on November 24, 2012 at 12:05:54:
If powering from the IH engine driven pump, other parts that go with it are the first control valve from the steering support, orfice plug, regulator and priority valve block, U shaped connector pipe and fittings and fittings to plumb the PS return line to the reservoir drain plug. Thats if you do it like IH did. Or a PS pump with reservoir will fit under a 300 hood and can be driven by the generator belt. Then just the lines need run from it to the unit.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
