Re: touch control cylinder head
Posted by CNKS on November 24, 2012 at 13:57:05 from (216.144.104.128):
In Reply to: Re: touch control cylinder head posted by joshua rod on November 24, 2012 at 13:48:54:
You can use the scraper I mentioned without abusing the head or block. You can use a small screwdriver to CAREFULLY pry it up after you have moved it slightly with the scraper. I have done it twice. You do not need heat, you just need patience. I had to have a cylinder head milled once because some idiot in a hurry jammed a screw driver between the head and block.
