Re: IH-1066 Steering Motor
Posted by Lavinia1066 on November 24, 2012 at 15:32:51 from (98.66.45.44):
In Reply to: IH-1066 Steering Motor posted by pete 23 on November 24, 2012 at 12:36:12:
Thanks for the info Pete23. I have tried both seals from IH one that is approximately the same length as the old seal and it leaked severly. Secondly, I tried the longer seal as you suggest and once the unit was tightened to the proper specs the unit would not turn. The longer seal seemed to be smaller in overall diameter, however it was the only other seal that the local IH dealer had for a 1066. Is there a trick to getting this longer seal in without locking the unit up. You suggested using an O-ring on the ends how can you hold it in place while the unit is alinged and tightened. Thanks for the help.
