Re: Stuck Key
Posted by Janicholson on November 24, 2012 at 17:08:23 from (96.24.99.126):
In Reply to: Stuck Key posted by David G on November 24, 2012 at 16:56:20:
It is a common Woodruff Key (IIRC) Take a cold chisel and use it flat against the shaft and peel the key out. Jim
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
