Re: alternator
Posted by Janicholson on November 24, 2012 at 17:22:03 from (96.24.99.126):
In Reply to: Re: alternator posted by morris roessler on November 23, 2012 at 22:10:50:
With Pete's info. in mind, the key must be on and the tractor not running. With the connection to the alternator removed, the connector to the # 1 terminal should show battery volts. If it shows less, or none, the wire is disconnected, or the diode is bad. Jim
