Re: 450 diesel
Posted by rustred on November 25, 2012 at 07:51:06 from (74.200.18.156):
In Reply to: Re: 450 diesel posted by El Toro on November 25, 2012 at 07:37:42:
yes, for sure need to bleed system. otherwise it will never start.
you need to start at the sediment bowl, but make sure the fuel is at least over top of filter level in tank.then bleed aux. filter or the rearward one.
then start engine and run on gas and bleed final filter or the front one.
then advance the throttle a bit and bleed injectors.
then flip to diesel and go to work.
