Posted by Janicholson on November 25, 2012 at 07:52:33 from (67.72.98.45):
In Reply to: Question for John T posted by D Sellers on November 25, 2012 at 07:15:35:
That would be a good option. A motorcycle battery would sure do the trick. The reason for the Ignition bypass using a (basically) 6v coil on a 12v system and a ballast resistor is to provide that sparky punch. There are 6v coils (early 50s Ford) that allowed the same idea with 6v systems using a ballast resistor on a 4 volt coil. If a person used one of those, a 5 amp diode could be used from the starter side of the main starter switch to provide bypass direct voltage, then prevent return voltage to the starter motor when the starter switch was released. Jim
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
