Posted by glennster on November 25, 2012 at 14:46:27 from (99.90.9.201):
In Reply to: Backfire? posted by Lucid on November 25, 2012 at 14:34:01:
lean fuel mixture can cause backfire-ing, also, ignition and valve issues. first stop would be a compression test to see if all the cylinders are within 10 percent compression. then check fuel delivery, then check distributor, possibly worn bushings causing point gap to vary. could be a cracked cap or moisture in the distributor too.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
