check the compression and your question is answered. without compression no way to burn the fuel in the cyl. and it is just slobbering it out. in short you need a head rebuild. also when an engine dont sound right the first step is the compression check, that is #1 not just add parts.why skip the most important step that tells the engine condition.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
