well if you where messing with it how come u didnt check compression with the thumb method as i said? telling u what to do and your still guessing.diagnose the problem before teardown. for all we know it may be the valve cover leaking and running down??? may have a broken piston and pumping oil out??? kind or annoying when you give the guy directions to find the problem and he comes back with another story, not attempting to find his problem he asked about. as i said # 1 is compression check.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
