Re: Backfire?
Posted by JRSutton on November 26, 2012 at 07:35:46 from (75.130.109.233):
In Reply to: Backfire? posted by Lucid on November 25, 2012 at 14:34:01:
Most likely not getting enough gas through the carb.
Sometimes they'll starve when you push them to work harder.
You can try richening it up a bit to see if that helps. It probably will.
If not - I'd give the carb a good cleaning and be sure you're getting good gas flow to the carb.
