Re: H axle bearing
Posted by Rework on November 26, 2012 at 08:30:34 from (67.222.196.16):
Hello Sir: If you still have some used "H" outer bearings, I am very interested. The old one I removed was a ND 1213R with one shield on the inside, and no grease groove. Seems to me this this was installed incorrectly. Shouldn't the shield be on the outside, especially if the lubrication is via the transmission grease? Why wouldn't one seal be better?
My email is "dekruse@huntel.net".
Thank you,
Rework
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
