Re: B missing under load
Posted by Matt E. on November 26, 2012 at 09:19:08 from (173.216.243.161):
In Reply to: B missing under load posted by Matt E. on November 26, 2012 at 08:15:32:
thanks Rustyfarmall, I must not have been holding my mouth right because I ran another search and found the 3116 as the recommended plug from the old posts.
I'll get a set of plugs and see what happens. If it doesn't help, I'll reset the mag timing again. The book says to lean the mag towards the block, bring #1 to TDC on compression stroke and then rotate the mag out until it snaps. Lock it down. Then it is timed right. Dad put the mag on the tractor but I'm not sure he timed it that way.
