Posted by PretendFarmer on November 26, 2012 at 11:45:33 from (192.249.47.207):
In Reply to: Backfire? posted by Lucid on November 26, 2012 at 11:36:55:
Im not sure how a piston could be stuck and have it run.
In my opinion, you should adjust the valves. You might be amazed at what that would do. If you have never done it, then its a good time to start.
I did mine with a .020" shim cold. Hot was .014" I think.
Its easy.
If you dont know how to adjust them, ask and I will give you step by step.
After you adjust, leave the valve cover off and run it. You(or at least I can) can tell if there is something out of order such as a valve not closing properly.
This post was edited by PretendFarmer at 11:47:04 11/26/12.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
