Re: 706d hydralic hook up to 3pt hitch back hoe
Posted by mkirsch on November 26, 2012 at 12:21:42 from (64.80.110.74):
In Reply to: 706d hydralic hook up to 3pt hitch back hoe posted by Michael Johns on November 26, 2012 at 12:08:51:
Can you please be more specific about what happens? What do you do, then what does the tractor do?
Does the lever pop back to neutral on its own? That is normal. You need to tie the lever back with a bungee cord or baler twine.
Are the couplers good? Bad couplers, or poorly seated couplers, can seal up and not let fluid flow.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
