clank/clunk in 2nd and reverse in my IH 560
Posted by Mark the Monk on November 26, 2012 at 14:03:22 from (156.142.184.69):
YIKES! I went to dump a load fm by bucket in 2nd gear, and when I went to pull it out of gear it was 'stuck'! I wiggled, and eventually 'yanked' it out - and then intially when I shifted the lever into reverse, it was like it was then stuck in one gear forward, and one reverse at the same time.
After giggling and bumping the clutch it 'released' and now shifts fine, BUT there's a loud clanking/clunking in only 2nd and reverse.
Did I break a gear??? OR, am I lucky with only a throw out bearing or fork to replace (it does need a clutch).
Thanks for any advice!
Mark
763 238 1733
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
